Whenever I drive straight or turn right, my sway bar end link is binding either in front or behind the mount where the strut bolts to the wheel hub on the driver side. It causes a vibration because there's constant pressure for example if im turning right and the end link is stuck behind that mount.
The driver side has a lot of clearance, so im not sure if the sway bar is too far to the driver side. Im not even sure if thats possible. Ive tried unbolting both end links and moving the sway bar closer to the driver side but it only moves up and down.
The picture below is not of a focus but a similar design. The circles in red are where its contacting. Ignore the green arrow.
http://imgur.com/yA8Ipc7
