So, many of you were or are having the same problem as me. I own a 2012 SEL Hatchback which other than the clutches going out, TCM going out, rattly headliner, rattly front suspension, and now crackling at full volume (even with the keys out of the car and radio off) radio, has been a good car
So, you just want to listen to the radio, your podcast, or turn off the radio so that you can get your tired little kid home after a late night out. Maybe you're enjoying a drive across the country or are stuck in traffic... CRACK STATIC!!!!! WTF!!!
So, when this happened to me I almost rear ended the person in front of me. Scared the ***** out of me. I blasted my dash with my fist and it stopped. Again, blast, stop. Again, blast, stop... Again, again, blast, blast, again, not stopping.
After a month or so I had to unplug my radio because it would constantly, at fully volume, pop, crack, and hiss.
Now, this is a three year old vehicle and this is obviously an electro-mechanical problem. This is inexcusable. If you are curious and took your radio out of the dash and took it apart, you would notice, that other than the CD module, there is only one PCB. Most of the components are surface mount other than an inductor, some electrolytics, and two amplifier ICs which mount to the chassis. If you looked closer you would see many of the through hole components (connectors especially) were not properly soldered (half empty pads). Signs of low quality control at whatever contract manufacturer Ford outsourced this to abound.
I reworked many of the components, all through hole components, especially connectors... I checked many things on the board and went over it with some optics. I installed it back in my car- 20 minutes later- CRACK POP!!!
So, I gave up. This car has shit on me too many times. I unplugged the radio and drove in silence for the next month and a half
Poor me
Then, this past weekend, I decided to give the radio one last chance. I plugged it in and was able to drive for about five minutes before my ears were assaulted with the sound of Ford Quality! POP CRACKLE!!! FULL VOLUME!!! WE ALREADY HAVE YOUR MONEY!!! CRACKLE!!!
So, by now I was smart enough to leave the four screws out that hold down the radio face and secure the radio. At a stop light I ripped off the face, yanked out the radio while still crackling and plugged in, and then beat it mercilessly on the dash. I beat that radio like a red-headed step child. I smashed it and smashed it like it was a Ford representatives greasy melon. The person behind me, I could see in the rear view mirror, put their hand over their mouth in a gasp.
Eureka! It started working! Flawlessly! Unto this day it is still working without even a hiccup! I subconsciously resorted to the troubleshooting and repair methods of my past life as a mechanic and figuratively pulled out the BFA (big ********g hammer)!!!
Why did this work. Well, most likely Ford (or whoever designed built/outsourced) this radio used shit components. Actually, they probably should have used soft-termination caps near the connectors and other places prone physical or thermal stress. Perhaps this resulted in a PLL going bonkers. Who knows. Most likely the merciless beating took that misbehaving component out to pasture for good. Yay!
Bottom line is that, being a single PCB solid state device, there is no reason (despite whatever excuses) for these radios to fail this soon. This is just poor quality and customer service. Period.
So, the radio is trash if it is doing this anyways. Why not just beat the hell out of it... first off, you may fix your radio, secondly, it is very therapeutic.
TLDR. A few taps with the BFA and your radio should be good as new.
