So, the car started, and still starts. It's probably a fuel pump. The manual steering doesn't kick in- the power steering pump goes out. The steering problem is probably in the steering rack. First check your owner's manual in the glove box for the location of the power steering pump, check the fluid level to be sure it's full, then turn the car on, and rotate the steering wheel all the way to one side then the other 10 times. With good luck that will solve the problem with the steering.
I'm still betting on the fuel pump being the cause. Try this test to see if your fuel pump is in it's final stages of life: With the radio and everthing else off, turn the key to the ON position, but do not start. Listen for the sound of the fuel pump, you should hear a whirring sound from the back seat. If that sound lasts for more than 10 seconds, the fuel pump is on it's last life. A good fuel pump should prime the fuel system for about 3-5 seconds. For some reason these fuel pumps will sometimes also stop pumping when you make a hard turn, and they are in their last stages of life. You can try just replacing the fuel filter, but the fuel filter will have to be replaced again when the fuel pump is replaced in order for the fuel pump warranty to be valid. To take best care of your baby [8)] be sure to change the fuel filter every 20-25k miles. Most people NEVER change the filter, but most people just drive a car until it quits and then kick it so they can scare it back into working condition.
It's doubtful that a bad power steering pump caused the car to stall. Unless Ford has drastically changed their pump design, it makes a lot of groaning noise when it's bad- but still works. If you experience an ebbing feeling when turning to one side or the other while driving- then the steering rack is most likely bad.
I assume the car is running- I'm sorry... your
baby still runs, so that's a good sign. I wish the best [thumb] and I hope you have a mechanic that you trust to look at the car because even though I sound like I know what's going on--- it's one thing to guess across cyberspace, and another to test and determine the problem in person. Do the fuel pump test and steering rack bleed procedures I described and hopefully that will show you what the problem is so you can impress some greasy guy named Jeff (or Stuart) with your auto knowledge [
