Duratec 2.3 vs Mazdaspeed 2.3
17K views 26 replies 18 participants last post by  felixthecat
#1 ·
Is there any difference in the two 2.3 engines other than the turbo on the mazdaspeed. i am wondering cause i would like to know if there are parts that can be taken from the mazdaspeed motor and put on the focus as upgrades. also same question for the mazdaspeed 6 or just the mazda 6 2.3.
#3 ·
Different head to support VVT and DISI. Block has incorporated oil squirters. Internals are most likely forged.
#4 ·
^^^ It's the same for north american focuses, Mazda's MZR powerplant which is the same as the Duratec has VVT while the Focus does not. That explains the small HP output change plus they may have different compression ratio, Mazda is more a performance expert with leftover powerplants from Ford; For Example (i.e. Ford Edge and Mazda CX-9 uses the same powerplant except Mazda stroked Fords 3.5 V6 to 3.7 V6, both have VVT but uses different compression ratio).
#6 ·
The Mazda 3 and 6 both use an electronic throttle body, which the Focus adopted in 2008.
#8 ·
^^^I dont think so... They wouldn't sell aftermarket 65mm tb's if the stock one was that size. I think the stock one is like 58mm or somewhere around that.
#10 ·
Probably not. If you are going to swap in the engine, might as well grab the ECU.
#12 ·
BTW Speed 6 and Speed 3 have same engine. Just Speed 6 has little difference in tuning so it makes a couple more hp.
#19 ·
Yes, thats what DISI stands for. Direct Injection Spark Ignition.
#18 ·
Also Speed 6's were AWD and more HP then the 3 but still slower and they were only made in 2006 so there is very view of them around
#23 ·
ah okay who do you think has the off the line advantage? And quarter mile if ya know?
I think the Mazda 3 has the suspension advantage off the line but wouldn't get the quarter?
#24 ·
Wouldn't it be a lot simpler to put a Focussport turbo on, & be done with it? I would say its a lot more fun adding a Turbo to what you already have, than trying figure out the wiring. You would think it is cake to add a wreck MS3 motor to a Mazda5. Afew years ago Sport Compact Car did a swap out, & had to run part of the dash in the glove box to get it running, after gutting the whole car! Add eletronics to a swap= big problems, at least for me. No issiues w/ carbs, back in the day.
#25 ·
I would be more interested to see if the ports line up on the exhaust manifold off the MS3, I've heard that it does, and other times it doesn't. If it does you could steal a ton of parts off a wrecked MS3, and build your own kit for the focus. Just too bad it runs a K04, which are known to have problems.
#26 ·
I thought the mazdaspeed3 had direct injection as well as the turbo?
