Custom precut window tint
2K views 13 replies 7 participants last post by  pasta
#1 ·
Has anyone ever tried the precut window tint before? The older I get the lazier I'm getting. I really don't want to pay an arm and a leg to have the windows tinted but I don't feel like messing with them myself either. Just curious how accurate the precut stuff is.
#8 · (Edited)
You'll find out on your first one. That works involves skills and patience that many do not have. The precut part ain't spit, and pre-cutting often makes it worse as you have no overlap to be able to be sloppier in location. It's getting the tint on with no wrinkles in it then getting it incredibly smooth after that with zero bubbles, what makes it last. Very hard to locate it perfect at first to have all edges be even, you will be lifting it again and again.
The factory tint work is done on them before the window is mounted in car. That way they can use a big long rubber squeegee to smooth it down all across the glass.
That back glass will show your stuff, it is NOT easy. Why even the $300 jobs fail often in a couple years or less.
#12 ·
That is why you make sure you use plenty of soapy water so the tint slides around and doesn't stick. Then you slowly squeegee the film starting from the center out. I've done several vehicles over the years plus window signs in stores. I'm just being lazy this time. My wife wants to have her front windows done on her Subaru too but I just haven't had the...umm...energy to do them. lol
#9 ·
That's pretty pricey. There a shop in my neighborhood that's 100$ all the way around. The back window is really hard to get right. If you feel like trying it the worst you can do is not like it and peel it back off. For 80$ you could get enough to do the whole car and still have some left to redo the back more than once. I've done 5 vehicles and only the last one did I get perfect. Well perfect minus one tiny bubble I couldn't get out. And that was with three other people who put big graphics on vehicles for a living. Side windows are easy. All the ones I've done by myself work ,yes, but look like crap from behind. If this is just your winter beater then who cares.
#10 ·
My winter beater. Sides are fine but the rear... Well you see. Furthermore with the air gap in those wrinkles dust and crap gets in there and messes with the seal of the rest of it. The parts not touching the windows start to fade. So eventually it will need to be redone.
If your set on doing it yourself. Don't buy the precut and by a roll or two of it. Cheaper and then you will have extra. Maybe do the sides and only hire the back out if your unsatisfied.
