So I have a 2005 focus ST with an oil leak it comes from the drivers side of the motor(looking at the front of the car under the hood) it comes out between the motor and trans my first thought was rear main seal, but if i follow the leak up it comes to the EGR Solenoid and the coolant passages over there... is this just oil being flung by the flywheel, or is there a seal over there? Note: highway driving causes the oil leak puddle to increase in size but round town trips the puddle stays small... i am baffled I have no idea where to start..
some back ground Knowledge
2005 duratec 2.3l
new valve cover gasket a month ago checked all bolts they are tight and gasket installed correct.
are there any gaskets besides the rear mail seal that would leak oil on that side of the motor? EGR meeting block gasket? the water housing block? maybe ??
please let me know and help me save my brand new driveway!
thank you [cheers]
2005 duratec 2.3l
thank you [cheers]
