What can you tell me about the 2016 Automatic ? I currently have a 2013 and haven't had any issues now the GF is looking at a 2016 sedan auto. Any good points/bad. Is the tranny still iffy ?
Itll fix his issue for sure. Usually keeps it smooth for a good time.You can try to do some 'clutch-scrubbing' , find an empty road, and go WOT to 45-55mph and slow to a stop, do it about 5-6 times and see where that gets you
So the 2017's will no longer use the DCT?Dont know if anyone has posted this yet but they are doing a redesign for the 17's for the automatics. My wife works at a dealership and they have had some issues with the 16's but it is all luck it seems to which have the issues and which dont
[giddy] The only way to improve the 2017 Focus auto. Is to get rid of it all together [giddy]So the 2017's will no longer use the DCT?
RR 9,10 or 13 speeds are easy, 9 and 10 just pull up the button and shift back into first from 5, 13 spd- 5 in low pull up the button back into first for 6th, flip the splitter button for 7, start shifting into the 2nd spot while returning the splitter button, repeat skip what you don't need.Explaining why the knob/lever on the stick does something different between axle shift & trans range types is hard enough, explaining the side button on a 13 or higher adds too much for most.
Haven't had the fun of actually using a twin stick of that type, only the Mitsubishi version in a Colt/Champ (chuckle).
Any kind of manual is fun to me, even the automated clutch types.
