I have a 02 zetec wagon with 160k
car died on the driver the other day. The starter would spin it over but it wouldnt crank.
I first checked the fuel. Fuel pump worked wonderfully (shot fuel out of the line like 10 feet)
I used the in-dash diagnostic to check the RPM of the car, and the starter could make it read like 187, so i knew that the Crank positon sensor was working.
I used a spark checker and found that none of the plugs were getting spark. thus i guessed it was a coil.
I took the coil and put it on another running focus and then it wouldn't crank. I deducted that the coil was bad
upon purchasing a 95 dollar coil from ford, i installed it and the car cranked up and idled awesome! problem solved right?
wrong. I drove it around the block and even before i could make it back it started to stumble when i would stomp the gas. It would idle fine, and in neutral it would rev to redline with no issue or stumble. whenever you put it in gear though (D or R) it would stumble and start to die.
It also gave a code for cylinder 1 and 4 misfires and for a ignition circuit A malfunction.
before long the car died again and wouldn't crank. Upon further testing (the same as before) i figured out that this coil had died too.
What are the odds of 2 coils going out, much less one going out within 2 minutes of driving?
I checked the wiring harness that goes to the coil. it was perfect until about a foot after the connector, where the black/orange wire was frayed. I could see the conductor for about 1/2 inch, but it wasnt broken or even hurt. it was also covered by the loom and none of the other wires were touching it or could have touched it to cause a short.
I dont know how to find out what is causing this car to fry ignition coils this fast.
Does anyone have experience with this or any idea about what i could be looking for without having to tear the loom off all the wires in the car?
I know it is a waste-spark system, meaning inside the coil cylinders 1 and 4 are linked and 2 and 3 are linked. therefore using a ohm meter you should get resistance between said connectors. On a known good car's coil, i get 12 ohms of resistance. On the 2 coils this car messed up, i get O.L., meaning unlimited resistance (they arent connected). this means somethng has fried both pairs of ignition coils.
there is a capacitor in the loop. I assume it is to prevent any waste voltage from traveling through the green wire to the computer. The green wire comes from the computer and goes to a splice which goes one to the center prong of the coils connecter and the other to a capiactior.. which could be bad?
anyone have any ideas?
At this point im thinking it could be the PCM has gone bad. I called a friend of mine who is a ford tech and he said that if the wiring harness is good, then it is a possibility that the pcm could be causing the car to blow coils quickly.
unless you guys have any better ideas, i think im going to find a junkyard PCM and get ford to reprogram it which will hopefully fix the problem.. sadly this requires me to purchase a pcm ($100), get it programmed to my car ($85) and tow-dolly my car to ford for them to do it. If the computer isnt the problem, i am also risking blowing out a 3rd $100 coil pack. all in the "hope" that the pcm is the problem?
