Which engine? RWD conversion.
19K views 53 replies 23 participants last post by  2ndss
#1 ·
I want to make a Focus track car. It will be used strictly for a track car. It will not be road legal, but that might change some day.
My question, is what engine? Its going to be converted to a RWD set up. Its going RWD because I want it to be capable of drifting.
So far here are some engines I have thought of:
V8's:
-Ford 4.6l (over used in my opinion)
-Ford 5.0l
-Ford 351 Windsor (also over used)
-Chevy 350 Small Block (never seen this done)
4 Bangers:
-Nissan KA24DE (turbo'd, making it a KA24DET)
-Nissan SR20DET
-Ford 2.0 Zetec (RWD configuration and turbo'd)
It will have either a 5 speed or a 6 speed tranny behind the engine. With a 4 bolt 8.8 Mustang rear end (probably out of a fox body).
Thoughts, questions, and complaints are all welcome.
#2 ·
RWD zetec boosted with a T5 and an 8.8 out of a foxbody. cool thing about the RWD zetec is the the wiring will be as simple as extending some plugs. crappy part will be making a subframe and mounts for it. only thing thou is i dunno how well that solid axle will work with drifting. prolly be best of you could use a newer model mustang independent rear from say a cobra but would just have the issue of it being 5 lug. im sure the independent rear would handle better.
#4 ·
I'm sure I can have the wheel hubs on the cobra IRS drilled and the studs put in to make it a 4 bolt.
If I can find a multi lug wheel that will accept the focus 4x108 on the front and the Nissan 240sx 4x114.3 on the rear, that would be a good option also and I bet I can pick up one of those cheaper.
#30 ·
Any LS block from a car- those should all be aluminum block. The LS engine is the cheapest way to get into a light all-aluminum V8. Yes, it's OHV, and not even with a good valve-train IMO. However, it will be the lightest and most powerful option. 302's with cast iron heads weigh about 450, aluminum heads and intake- just under 400- slightly more with larger MPI intake manifolds. An all aluminum LS block is going to be 100 lbs lighter than that. Wiring is all over the place for it because this is now the choice, logically, for hot rod builds. The Gen1 and 2 Chevy blocks are horrible choices compared to the LS. You don't have to build a big giant stroker either. A large bore LS6 from something like a Denali with a shorter stroke crank would yield a screamer, and then you'd need a $1500 Harland Sharp shaft rocker setup, and you're good for RPM screaming that would drown out any fart canned Vtec. I don't know anyone who wouldn't prefer the 8k+ rpm scream of a V8 over a 4 cyl.
Check out how cheap it is. I wish the modular Ford blocks weighed less, but those things are so completely huge when compared to the LS that it's ridiculous. Believe me it is ALOT for this old ChryCo racer to recommend a hated Bowtie for anything- but since I started looking into the LS, I can't see any other vehicle for built cars.
On the other hand, picking up a Ranger D23 Duratec would yield an option nobody has done either. You'd have to do a lot of welding to make either one RWD, so just compare the engine and performance cost. That de-stroked LS6 will weigh more than a turbo D23- but look at the power.
One thing you didn't think of was either of the Cyclone V6s. Bell housings could be made, and these (no research) are likely easily converted from FWD to RWD. Ford did it with Ecoboost for a 400 hp 32 Ford 3 window coupe. Ginetta uses both the D30 and Cyclone D35 in their race cars, so someone out there might be selling a cam. The D30 might be an easier bet since it doesn't have VVT.
I still think you'd be hard pressed to out price/perform the aluminum LS.
Here's another thought- short wheel bases do well with RWD, since you're doing all this welding any way, why not brutalize a wagon removing the about 18" of the back seat ?
#7 ·
Since your finished car will still be fairly light and not need a lot of low end torque, a 351 Cleveland 4V. While Ford loosely used 2V and 4V to refer to 2 bbl and 4 bbl carbs, in this case the 4V had larger ports and more hp potential. Beacuse of weight, Mach 1s were Cleveland 2Vs.Think DeTomasa Pantera. I think the Boss 351's might have been Cleveland 4Vs. Powerband pretty faint below 4,000 rpm, but then the rush to redline is awesome.
I just found this in a web search and I quote it here:
"If you have any doubt about the Cleveland heads breathing well, compare the valve diameters to the 390, 427, 428 and even the 460 Police Interceptor. The Cleveland 4V has a bigger intake valve than any of the other engines except the 460 Police Interceptor! The 351C 4V exhaust valve is only 0.020" smaller diameter than the 460 PI, and only 0.010" smaller than the high performance 427. Even the lowly 351C 2V has intake valves larger than the high performance 390's and 428's, and the exhausts are larger than all 390's and some 427's, 428's and 460's."
#52 ·
Woot Woot Cleveland!
Yeah! That's what's sittin in my yard. '73 cougar xr7, 4v, 4brl, 4 bolt main, 9" rear, c6 for a focus swap will have to go w/tremec 5 spd and 8.8 rear. I was thinking some day a swap into a fox body, and a 5.0 swap in focus. But most likely I'll do a cobra kit car w/my dad.
Good luck 73 Cleveland 4v aren't too tough to find, but 71 heads to kick up hp are tougher to get.
#11 ·
Hands down I say Duratec, simple as finding a ranger donor truck, it's RWD configuration already, getting more power is easy, and last but not least I've been wanting to do it. Also it's light and ready for a fight lol
#15 ·
^^Not true, remember the one that had the whole motor and tranny moved to the back of the car? It's from a long time ago. Technically that was a RWD zetec, you said nothing about rear engined lol. Ether way I would love to see the zetec or duratec turned sideways in the engine bay of a focus. It would be the #$@! IMO!!
#18 ·
my focus is a sbc..
not a P[:)]SS ol 350. but a ls is sbc none the less.
my vote goes to either a 5.4 dohc out of a navigator or a rwd zetec. depends on what you want.
good luck
#20 ·
I'm going to run the engine with megasquirt. So it's going to have to be fuel injected.
The inline 6cyl 2jz or RB's are tooooo long to fit under the focus hood.
Should I do this to the hatch back or a sedan? The sedan would be the ultimate sleeper with this kind of thing, it wont be too top heavy for drifting, and I love my DD sedan.
For the v8's, I'm going to narrow it down to either a 4.6l Ford, 5.0l Ford, or a Chevy 350. I'm looking for a multi port fuel injected engine and to my knowledge, there never was a multi port 350 chevy. So that leaves me with the 4.6l and the 5.0l Ford engines in the v8 lineup.
How many people would like to see the SVT Zetec in a RWD focus?! Turbo'd of course.
Custom rear subframe for a Nissan IRS. Custom drive shaft. Custom exhaust.
RS front fenders and quarters to make it a bit wider and meaner looking. Rally lights on the front. The rally lights will either be mounted on tabs that come out of the bumper or a dune buggy type baja bumper. Stretched tires. Lowered. Etc etc.
#21 ·
The more I think about it, I would like to keep the Zetec or swap in the SVT Zetec because I can tune the stock computer for all the mods I do and still keep it emissions legal if decided to make it road legal.
That doesn't mean the stock ecu can't control something like an SR20DET in the zetec's place though. [deviltail]
#23 ·
go with the 5.0 coyote mod engine with an edelbrock S/C on it, it should fit under the stock hood too 5.0l version is coming and a t5 tranny and the 8.8 rear end the kugel kit for the rear end seems reasonably priced unless you are good at fab work
it will not be too top heavy iv been drifting in a wagon yes i know with front wheel drive but it barely tilts,you are also going to be sticking a v8 into it that will bring the cog down and the rear axle will help spread the load so drift all you want, and the 5.4l is too big the focus has a 5.0l engine bay
