Hey everyone, new here. Need some help with my brakes! Drive a 2006 Focus zx4 2.0 5sp. Couple months ago my brakes started sticking, causing vibration on the highway and not having to push the brake pedal to stop. Took my wheels off and my front right caliper was bad, so I replaced calipers on both sides along with the pads. Problem was fixed for a couple days then came right back! So we replaced the front brake hoses on both sides. Problem still wasn't fixed so I took it in to a local, small garage to get looked at. He said my front, right wheel was burning 200 degrees hotter so it wasn't the master cylinder or lines. Could still be the caliper or abs (abs light has never been on). Today I replaced the caliper again and the problem is STILL there. Sometimes it gets so bad I have to pull over, turn off my car and pump my brakes so they can release again when I turn it back on. Otherwise I'm stalling coming out of first and the gas pedal to the floor doesn't get me very far. I plan on taking it to Ford to get looked at but has anyone else had this problem?? I would rather fix it myself if possible as Ford charges an arm and a leg. Thanks!!
