speaker wire colors for a 2010
2 reading
40K views 5 replies 5 participants last post by  seantheavatar
#1 ·
just pulled my deck and the wires colors in the harness are diffrent then the ones from the chart that is posted here. does anyone know the correct color/speaker wires for a 2010
#2 ·
stereo wiring
sooo this is where i got my diagram from.. you shouldnt really need it if you buy a wiring harnes.. its much less hassle, more reliable and clean. they're worth the 20 bucks. but this is the diagram posted if it helps..
2010 Ford Focus Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Red
Car Radio Accessory Switched 12v+ Wire: Gray/Orange & Violet/Orange (This vehicle uses the can data network for accessory turn on.)
Car Radio Ground Wire: Black/Blue
Car Radio Illumination Wire: Gray/Orange & Violet/Orange (This vehicle uses the can data network for illumination and dimmer controls.)
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black
Car Stereo Amp Trigger Wire: Violet/Red
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
#6 ·
For anyone visiting this later on searching for answers that clearly aren't being provided. This car utilizes a CANBUS System. Which cannot be hardwired into as it is a system for all the Electronic Control Units on the vehicle to communicate with each other and needs to be decoded. You must use an adapter with a decoder connected if you want to access Ignition/Accessory 12v, Illumination, etc. otherwise you could wire a custom Ignition 12v wire which is highly unrecommended unless you want a huge project most of you don't have the expertise for and a deck that has no other features.
