They were simple to put in. I got a 13mm deep and took out the nuts on the back. Each light has two little tabs that also hold them in one just fell out the other I got a small screw driver and gently pried it out. Now looking at the new corners, they look like there is no way a bolt will thread on it's just a plastic pole. The nuts will re-tap that. They just click in, make sure you change the bulb to orange: 1-to stay legal, 2 with just the clear one in you cannot tell that they are even on. It's a little tight without a jack. I'm heavyset and wasn't too much of a problem.
The tail-lights I was looking at r the ones on eBay: Smoke led tail lights, right now they are a bit pricey but hopefully they will eventually come down. I mean $200 for a set of tails, come on. I would also be looking for a smoke 3rd brake light. Right now I going for a smoke look instead of clear. I have a broken fog light and was thinking about getting the smoke ones off of eBay.
