Hey all... today i started a small amount of work on my first long term project on my car... wire tucking.
Wiretucking is where you remove panels from your car and any wiring you see, gets hidden within the body structures, to achieve alot of this you need to extend the harnesses.
I plan on running only a dash, door panels, and center console, and maybe a-pillar trims, the rest will be removed, and hopefully summer of 09, i will have a nice sheet of Liquid grey paint layed in the interior, so the inside paint will look just as good as the outside paint.
this will be a long project, so just hang with me. and with any good project, i will be sure to include ALOT of pictures.
questions comments?
here are pictures from today.
gutted hatch:
junk in the trunk, the rest of the rear panels, i havent removed the rear arm rest panels as of yet... but soon...
I didnt show how to remove the rear panels or anything, because enough people have done suspension enouhg to know how to take the rear panels out, and rear seat deletes.
but i have a little info below:
yesturday while driving i heard rattles, and i assume some of it is from these little buggers:
there are 6 around the rear area, 3 on each side holding the rear trim around the rear seat belts.
so what you do is get a pair of pliers, Leatherman FTW!
put your finger on the outside of the hole, and then attach the pliers to the other end and pull
now its pulled out, and hold your finger there so it doesnt drop into the body
and use a magnet or whatever to just slip it out, i used a magnet so i knew it wouldnt drop down
then after the clips were pulled out, i just used alittle touch up paint to cover any bare areas...
motorcraft OEM FTW!
i then noticed the tops of the struts and the strut plate are not protected the best, they had a few spots of surface rust, so i taped them off
and painted them black
oh, and thanks ford for the booger of sealant on my left rear wheel well.
thats it for now... thanks for looking, and feal free to subscribe, i will show and take many many pictures, because i know to have a good thread, you need lots of lots of pictures.
NA FTW!
questions, comments?
questions comments?
gutted hatch:
motorcraft OEM FTW!
NA FTW!
