What octane do you use?
  • below 85
    Votes: 2 1%
  • 85
    Votes: 6 2.3%
  • 87
    Votes: 166 65%
  • 89
    Votes: 20 7.8%
  • 91
    Votes: 23 9%
  • 93
    Votes: 29 11%
  • 95
    Votes: 3 1.2%
  • over 95
    Votes: 7 2.7%
Poll: What octane do you use in your duratec?
19K views 121 replies 69 participants last post by  wood_e
#1 ·
Poll-- What octane do you use for your focus? I know to a lot of you it doesn't matter. But I would just like to know.
PS. regular in my area is 87 and plus is 89. If I use 87 or lower I have a rough idle. Probably cuz my ECU is just so used to 89.
#7 ·
these cars are made for 87 ONLY!!! only time you run a high test gas is with a tune. if you dont the ECU will not allow the spark plugs to get hot enough and you WILL blow your catilictic coverter out and i hear there about 1k-1500.
#13 ·
ive used 93 on my 06 since i drove it off the showroom floor and 19,000 miles later still no problem and all i have a cai, roush exh, and a 75 shot it says only use 87 in the manual but who really listens? or reads it
#17 ·
06roushzx3 ehh its not a good idea cuz your car isnt made for 93 you have to get a SCT fash to run it. PLUS you should get a tune for your exhaust and NOS cuz your car is running stock #'s for air fuel and stuff like that. the flasher will give you alot more power and be way safer to run also everyone here will agree with me. but problem is the ECU knows it needs to run spark hot enough for 87 octane. well 93 needs a hotter spark or it wont all ignite which means the gas that doesnt burn goes into your valves and exhaust and could cause o2 sensor to go or a CAT. and are cats are in the exhaust manifold so you may want to re think what your doing before you hurt your car but hey just my advice
#19 ·
yeah i do need a tune but for the 379 for the sct and then another 275 for a tune and dyno
#22 ·
People, people! Please read this carefully:
93 octane is not "better" than 91 is not "better" than 89 is not "better" than 87!!!
With higher octane, a hotter spark is required to ignite the mixture. Period. It doesn't burn faster or better or more explosively. It DOES allow engines with more ignition advance to have a higher safety margin against detonation. It does NOTHING, NADA, NICHTS for an engine that is not tuned for it. Of course, the corner gas station is more than happy to sell you whatever you ask for...
#23 ·
My stepdad's Taurus gets some pinging on 87 (what it asks for) which promptly goes away 100% on 87, so he uses that. I don't know if that's a proper use, but it does seem to work. We have 87, 89, 93 I think, occasionally a station has 91 instead.
As for new cars that don't ping or urn perfectly fine on 87, I would just do 87. Like others said, at best it's a waste of $, but do what makes ya happy I guess.
#24 ·
My stepdad's Taurus gets some pinging on 87 (what it asks for) which promptly goes away 100% on 89, so he uses that. I don't know if that's a proper use, but it does seem to work...
Then there's something causing the car to be prone to detonation, and using a higher octane is just putting a band-aid over the problem. Maybe clogged injectors or something causing the car to run lean? Could be lots of things.
#25 ·
I've used 89 in my old 92 Dynasty. As things collect 100s of thousands miles, detonation is unavoidable sometimes. Running a high octane to avoid pinging is a valid application, short of an engine overhaul.
#30 ·
http://www.jimhightower.com/node/1777
87 tuned with dealer software and getting 37MPG on the summer blend, and 35 on the winter blend.
92 octane (and tuning) didn't net any more MPG (in my case), but lots of "grunt".
