Please HELP ME QUICK~!!!!
852 views 6 replies 4 participants last post by  drewzx3
#1 ·
ALright i need help with how to use the belt tensioner. I have the bolt off my udp, and the belts still tight so how do i use the belt tensioner thing to loosen it up. IS there a bolt i have to loosen? or what. Thanks for ur help!
#2 ·
you dont loosen the bolt you turn the bolt like your going to tighten it but it just moves up because of the spring and you will be able to get the belt on.You have to get down on it pretty hard.When i put mine on after i got the wrench all the way down to the control arm I put a big tie strap on it to hold it.
