What is the max allowable gap between the piston itself and the sleeve. I am getting some controversial numbers here, like when the motor was built it was put together with smaller pistons or something.
The Haynes manual says it should be very tight> piston and rings class 1 3.3399 to 3.3403
I think I need bigger pistons.
Do you guys need more info?
Ok so I figured it out I need 84.8MM pistons. Does anyone know where i can get them cheap?
