So like many of my fellow Focus friends, I changed the timing belt, tensioner, and pulley because I was not sure when it was done by the previous owner. It was my first time doing this job on any car so naturally I searched the forum and found that people kept on reffering to Tom. I was able to get into contact and he ofcourse gave me very good advice on the specific things to look out for. Again Tom, thank you for all your help! Long story short, I got the belt and tensioner, and pulley all changed out, new valve cover gasket, got it all tightened down and now ready to restart the motor. Turned her over, let her run for a little while and no check engine lights! Tom specifically mentioned that if I were to get a p1381 code to call him and he will walk me through the steps. After about an hour and a half of motor run time (the car was still on jacks do to other maintenance being conducted) the engine light came on. I was able to fix what I was working on and drive her over to autozone and had them check the code. Mind you, the car sounded like it ran perfectly! No bogging, not shuttering, no loss of power (didn’t get on it but it responded fine when I pushed the pedal.) sure enough it was the p1381 VCT over-advanced code. Called Tom up and he was very very specific on what to do to fix it! He specifically asked me how long it took after the motor was on for the engine light to come on. Take note of how long it takes! Tom said that since it took the motor being on for an hour and a half to realize there was an issue, the timing is just barely off! The steps to fix this is very simple but crucial so pay attention to what your doing and TAKE YOUR TIME!
1. Take valve cover off
2. Put rags under the intake cam gear
3. Pop that plug (t55) off the end of the cam gear, oil will come out so that’s why the rags were there. Tom mentioned that about a coffee cup amount can come out so put down a lot of rags, you don’t want to soak your brand new belt! For me it was extremely cold here so the viscosity of the oil was thick and not too much came out.
4. Get some vice grips or an adjustable wrench and hold onto the cam keeping it in one spot! THIS IS CRUCIAL!! You need to make sure you can hold the cam in one spot because if it moves too much your timing will be off even more!
5. The cam bolt is a E18 torq socket. I did not have this socket so I ran autozone and they didn’t even have it. Went to Home Depot and it came in a kit (did not sell individually) for $24 by Husky... Loosen the cam bolt, you don’t have to loosen it much just break torque and that’s it. Remember HOLD THE CAM STILL!
6. For me since I got the over-advanced code, I had to turn the cam with the wrench or vice grips whatever you use, in the direction the motor naturally spins. This is where you will be correcting your time. Mine was so slightly off I just barley had to move the cam, not even a notch length on the cam gear!
7. Continue to hold the cam in the new position and tighten the cam bolt back up!
8. Re-install the plug at the end of the cam gear
9. Re-install the valve cover nice and easy and make sure you get all the bolts seated down correctly.
10. Nobody would clear the code and I don’t have an XCAL so I disconnected the batter for 10 min and then went for a drive. This time I drove around for a good hour and a half and no engine light so I would call it good! You can get another engine code and it if says the opposite of what you got the first time then obviously you turned the cam too far.
I apologize for this being alittke long but detail is key, especially anything with timing. Again I can’t thank Tom enough for helping me out with this issue and answering all of my questions. I’m not too sure on how to tag other users so if you know how please tag Tom in this. Hope this helps anybody that may be having the same trouble of their own!
