P0131 oxygen sensor?
14K views 9 replies 4 participants last post by  saintsfins
#1 ·
I filled with Walmart gas yesterday, and the car stumbled for a second when I started it. I also noticed that the fuel gauge didn't show full. The check engine light came on within a few miles, so I read it with my scanner. P0131, bank 1 oxygen sensor. I cleared it and drove to work this morning. The car feels fine and the code didn't come back on. I guess it could be crappy fuel and I should just wait to see if the code comes back on? 115K+ miles, and I've never replaced a sensor on it.
#2 ·
Sometimes O2 sensors don't go out all at once. Mine produced an intermittent CEL for a while until I replaced it. If you have a good idea of your typical fuel economy, keep an eye on that as that is another indicator of an O2 sensor going south. Pretty easy to replace. Either buy or get the loaner O2 socket. Break it loose with a breaker bar and it should be a 10 minute job.
#7 ·
P0131. Funny I actually found some time last night to put it in. I was suprised how easy it came out (no PB Blaster).
My research on this forum found everyone with this code had it resolved by replacing the sensor. There were lots of people suggesting a few other items to change first, since the sensor is $70, but no evidence that there was any other reason people saw this code by itself.
#9 ·
The fuel gauge issue only happened once and I was able to put a few gallons in it the next day, so I suspect the gauge was accurate, but the hose just clicked off before filling the tank. I had the recall done a few months ago. No issues, so they just updated my PCM. I'd think a bad/failing evap hose should now (after the recall) throw a code. From everything I've seen, P0131 points to the upstream O2 sensor, so that's what I'm trying.
