Some of you may know how frustrating it is to install the output shaft seal/CV axle seal on the 4F27E Automatic transmission if you don't have the right tool. You may also have ruined a seal or two like I did using the wrong tool. The problem is that the right tool (OTC 307-572) is scarce and excessively priced if you find it. So I designed one that works just as good and 3d printable. You use it just like the OTC tool but you hammer the flat back instead of using a driver handle.
Let me know if you have a 3d printer and would like the file or if you'd like one printed. I can give you a deal you can't refuse 😜.
