One touch up/down power windows stopped working
33K views 8 replies 8 participants last post by  sam1111
#1 ·
I noticed this morning that both front driver & passenger's power windows are no longer responsding to the long/deep press for the one touch up & down.
It goes up & down normally with a regular press.
Anyone else experiencing this? I have the 2012 Titanium Hatchback...
Thks.
#2 ·
Mine do that every once in awhile.
Try this:
Hold the window button down until the window is all the way down and keep holding it for another for another 3 seconds then immediately hold the button up until window is closed plus an additional 3 seconds.
That should hopefully solve the problem for you.
#3 ·
It happens from time to time, usually whenever the battery is reset.
The owners guide tells you how to turn the one touch feature back on:
You must reset the bounce-back memory separately for each window
after the battery has been disconnected.
1. Lift and hold the switch until the window is fully closed.
2. Release the switch.
3. Lift the switch again for one more second.
4. Press and hold the switch until the window is fully open.
5. Release the switch
6. Lift and hold the switch until the window is fully closed.
7. Open the window and then try to close it automatically.
8. Reset and repeat the procedure if the window does not close automatically
#7 ·
Brilliant, love the search to find these tips. My windows were working erratically, so i figured it was the Body Control Module (computer) and disconnected the battery.
That fixed the sticking problem where they occasionally would not open/close, but wondered why the one touch operation no longer worked. Been driving for days without it and anoyed.
That 3 second hold process fixed immediately. Thanks!
