Was changing thermostat housing in my 03 Focus Zetec - had to take battery and case out to get at the hoses etc - when disconnecting negative terminal, it just fell apart where it attaches to the battery - put a new connection on the end of the negative terminal but not sure how to reconnect the two smaller wires - one is obviously a ground coming off the frame - the wires were connected one on each side of the terminal - got hooked up and got battery power but the car will not start - just keeps turning over like it would if a coil wire was disconnected - have no idea if this has to do with the negative terminal stuff - any ideas??? Tx
