need spark plug tube seals 10 focus:
1 reading
7.1K views 7 replies 3 participants last post by  badazz2010focus
#1 ·
what is the felpro part # and do you need a special tool to remove them is it even possible to get them by themselves?
#2 ·
I believe you have to replace them by removing the valve covers and they come with the valve cover gasket set. At least that is the setup on my 06 Focus. The Felpro part number for the 06 is VS50639R-1, and it appears that it fits some of the 10's as well.
#5 ·
You have to remove the valve cover to change the plug seals. They are the two semi-square gaskets and the smaller long rectangular one. Two plugs fit inside the longer one, and one plug each in the square ones.
If you actually mean the seals under the individual ignition coils, then you mean 'coil plug boot' as the part name.
