So I'm doing my first M/T fluid change on my 2010 SES and because I have a habit of driving it a bit hard, I would like to put in something a bit better than the OEM recommended fluid. From experience what would you guys say is the best to use?
First of all, there is no reason to call anyone names. Consider this a warning.Ford "Honey" - XT-M5-QS is a comparable 75w90 gear oil dork there is a HUGE thread on this.
You want to give out wrong information go for it.Yes, I did read the thread. Have you bothered to read the thread that was linked from Terry Haines, the foremost authority on the MTX75 transmission?
Independent lab tests have proven Diesel engine oil is the closest formulation to XT-M5-QS. I don't see anything in your chart above about additives. You are only showing viscosity and wear comparisons, not formulation. You should also be aware that lubricant manufacturers aren't always completely forthcoming about their product. Lab tests will reveal data that the manufacturers aren't willing to release.
Independent testing is the reason why Royal Purple no longer suggests the use of Syncromax in the MTX-75, but rather HPS 10w-40--because it is closer to the formulation of XT-M5-QS.
Keep in mind that engine oils and gear oils are not viscosity-rated using the same standard. The actual viscosity of 15W-40 engine oil and 75W-90 gear oil are very close, but rated by separate guidlines. IT IS THE ADDITIVES THAT ARE IMPORTANT.
Thank you for your blessing. You also have my blessing to take Ford's word on the subject, if that's what you want to do. There are owners I know who have run ATF or Syncromax in the MTX75 for over 100,000 miles with no issues also. That doesn't necessarily mean it's the best lubricant to use.You want to give out wrong information go for it.
You can run what you want, but Ive ran over 100k miles with multiple 75w90 gear oils without issue in the MTX75 and the Getrag 285.
15w-40 engine oils fit right into your viscosity chart above, right next to 75w-90 gear oil. Perhaps if either of us can come up with more than just viscosity information, we might further add to the discussion. As it is, I won't outright say someone is wrong (and call them names) about the subject as you do, until there's more data available to prove someone is actually wrong.Yes I did read what Terry had to say.Post the Terry Haines Info of his lab results i cant find them...
Well, for one, I don't understand why people argue or get emotional about it.Guys, it's transmission fluid. You must have better things to do.
Toby
I was just trying to share the information that I had available to answer the question, no need to attack me about it.You are wrong
Ive ran Redline MTL, Amsoil 75w90 and RP Maxx gear 75w90 in Both the MTX 75 and the Getrag 285 SVT now for a combined mileage of over 100k NO ISSUES shifts way better in both transmissions. RP Maxx gear feels the best.
I change the fluid every 30,000
Synchromax is too thin, enjoy all the brass in your trans from jacked up synchromax...
Besides you drive a 2012 so your input is nil enjoy your DCT
Here is the definitive thread on trans oil
http://www.focusfanatics.com/forum/showthread.php?t=278437
So we should all keep our Foci stock ? Just because you can make it a performance vehicle it works doesnt mean you shouldJust because something works doesn't mean that it is correct, this goes for any fluid referenced in this thread.
That is what I was trying to get at .... and I was not indicating that a Focus shouldn't be modified. Look at my Contour, that should clearly show that.So use the oil you think works best in the end thats the oil that will work best for YOU
Well, no... The fluid that is specified for the MTX75 today is not what was originally specified for it, so it was not designed to use it. It was not even available when the MTX75 was designed.Elizabeth has it backwards-the trans is designed to use that fluid. The bearings, syncros and other parts are all tested using that lube. Why would you use something else?
