motor mounts replace ?
2.2K views 13 replies 8 participants last post by  oblivion2kx
#1 ·
needing info ,has anyone done motor mount replacement specifically vf-engineering or cfm mounts i have been told anything more then lower torque mount and the car shake/vibes car is driver but looking to turn into back road racer.
#2 ·
They are all really easy to replace. The dogbone is two bolts in and out. Really firms things up without adding a ton of vibration. The transmission mount makes things a bit firmer with more vibration and the passenger side mount doesn't really do a whole lot but adds a ton of vibration. This has been my experience.
#4 ·
I have solid mounts on my srt 4, and it definately increased the vibration. im not sure on the focus, but i heard the dogbone is the easiest and causes the least vibrations.
#5 ·
just do them all. i started with the dog bone and then the pass side went out and then the drivers side went out. more vibration as a whole but feels so good.
#6 ·
I just did the VF lower dog mount and my car shakes like a massage chair below 1000 rpm
My solution: Spray the retaining brackets with a vibration dampening spray .. then install it.. [werd]
#8 ·
if you calibrate them you will be fine I have all 3 with ATX and shake no more then stock.
