Hey folks,
I have had severe bump steer as long as I can remember. Ive read up on bump steer and am pretty sure this is what is happening.
I know that my front sway bar bushings are completely shot but cant imagine it would be causing the wheel to jerk so hard. I understand lowering/lifting a car is a common cause. I installed the SVT kit, control arms, tie rods/end, and sway bar links really soon after I got the car though, so not sure if it was present before that or if it was only present afterwards.
I see other cars and the Mk3 Focus have bump steer correction kits which are essentially adjustable outer tie rod ends, but there are none for the Mk1. All I can find are adjustable sway bar end links which dont seem neccessary unless the sway bar or struts are replaced with ones thst have different mount points, but in any case I wouldnt think that would directly affect the bump steer issue. Ive had the car aligned a few times - once after the front end work, once after the rear end work, and once after installing my SVT wheels and new tires. It has been over a year since my last one but the problem has always been present so its hard to believe thats all it is. Im kind of at a loss for how to fix this. I dont want to let other people drive the car the way it jerks now.
How are other Mk1 folks addressing bump steer? Am I missing something obvious?
