Lower Radiator Hose Installation Help!
11K views 10 replies 7 participants last post by  amc49
#1 ·
Does anyone know how to remove & install the lower radiator hose on the SVT?
I know the clips are going to be a pain but access to the lower two outlets… that will be the problem.
Any suggestions would greatly help.. currently the car is at my job and luckily I’m borrowing another car to get to and from work, But time is of the essence. I would like to fix this myself on site but if I can’t by Friday I’ll have to chalk this one up to a local garage that is a few seconds down the street.
#5 ·
Been awhile but I know I didn't do any of that..........getting the factory clamp off is the issue and use a standard issue worm drive clamp at least on water pump inlet when going back together so no trick install tool needed.
I know on those type clamps I always first use a screwdriver pushing against one of the wings to slip-move the clamp wings radially to where they are easier to get to before trying to actually remove clamp. I hate those things.
#10 ·
So I have everything ready to go however I noticed the replacement hose does not have a heat shield on the upper hose.. I had a few idea's/options for it and just need a few opinions.
Should i use the Advanced Auto Heatshield hose sleeve, a bit of header wrap or cut and tie a part of exhaust repair kit metal and wrap it around the hose? Thanks.
