Left Turn Signal Flashing Fast
51K views 23 replies 12 participants last post by  ziggyzetec
#1 ·
I assume this is the turn signal relay that has gone out or spazzed out or something. I checked the owner's manual but can find where the turn signal relay is...anyone know? The right one is fine, and the hazards are fine.
#8 ·
yea one of your bulbs is blown this happened to my friend nick one day when we were driving and it was his rear taillight that went out he put a new one in and its fine
#9 ·
Quick and dirty explanation of what is going on. When a bulb burns out on a turn signal the overal circuit load drops causing the blinker to blink faster. The blinker system works on a Resistance/Capacitance or RC circuit. T=RC where T = period(time required to blink the light on and off), R = resistance, and C = capacitance....so if you take 1 of the two bulbs out the resistance becomes half of what it originally was so T=(1/2)RC. This means T is equal to half of what it once was meaning the time require to blink the light on and off is cut in half thus making the blinker blink faster. I believe that is right. If someone else knows otherwise let me know so I don't go on thinking the wrong thing...but I do believe that is right. I know the T=RC part is right and I'm pretty sure the blinker system is an RC circuit.
#10 ·
Thanks Bill Nye[;)]
Yes you are correct.[thumb]
#14 ·
[headbang] rock on dude! Classes are startin to get hella hard for me but I'm pushin on through. Bad thing is, I'm off by a semester on some of my sequence classes and I'm co-oping....all that combined puts me 1.5 years behind on graduation. Oh well [:)] I'll be out of school in December of 2007 if everything goes ok.
I put the EE in geek! [:D]
#17 ·
flasher
not always is it a bulb. my wife's SUV had a bad flasher unit. was doing the same thing twice as fast on the left side but i checked and all the bulbs were fine. just to make sure i replaced it still no fix. had to replace the flasher unit.
#20 ·
I believe that modern cars including Foci use the discrete model instead of the analog one that you just described. Why did I come to this conclusion? When I was rewiring the rear tail lights, I made my b/u lights act as the blinkers instead of the stop lights. The stop light bulb (3157) filament is rated 27W, and the back-up (921) is only 18W. The frequency did not change a bit. Later, when I was trying to use a 13W bulb (912) as a blinker, the frequency of flashing became much greater. By using an analog model, I could not explain why the frequency does not change at all when the power consumption decreases from 27W to 18W, yet it starts blinking way too fast when the power decreases further to 13W [confused]
P.S. I am majoring in EE too [thumb]
#21 ·
That's very odd that it didn't change the frequency when moving from a 27W bulb to a 18W bulb but changed when using a 13W. [scratch] I didn't go as far as to test out the circuit but that's the first thing I could think of when it happened to me, just assumed it was a normal RC circuit. Interesting find though, you've got me thinking now, lol. I can't explain that, lol.
#24 ·
intermittent
Hi. help needed. my rear left indicator works then stops working and starts working intermittently. while its not working it flashes faster, when it does work all is fine. I checked the bulb and its fine. I then changed my head lamp as I discovered that was out but my indicator still works intermittently! I cant see any other lights that are out causing this problem. Everyone keeps saying change the bulb but it does work for a week then doesn't. cant find a reason why?
