DO NOT OVER-TIGHTEN THE BOLTS!!!! It will cause it to leak again! I forget the exact torque spec but I believe its about 6ft-lbs. Trust me I ruined my first replacement by using the man torque method and the gasket leaked again replaced it use specs and no leaks.
That's a fact on every vehicle. Something like that would be a good excuse for me to get one of those digital torque wrenches since none of mine do in-lbs or lower than 10 ft-lbs except the old fashioned bar style. I assume the Zetec uses one of those molded rubber gaskets that you insert into a slot around the VC. On those I don't supplement with RTV like I did on older flat gaskets without grooves. I do still tighten it to what I call "wrist" tight which is about all the force you can put on a ratchet with just your wrist. It's less than 10 ft-lbs. The trick is not using your arm, and only using your wrist. Some of you bigger beefcake guys might want to test this out on an inconspicuous bolt somewhere to see what you end up. I had a mechanic buddy a long time ago who got me into testing what torque I could apply with X tool so in some cases, I wouldn't have to go locating a torque wrench.
A regular handled ratchet, for example, I can put about 20 ft-lbs on the first time, and if bear down on it a second time I might get it up to 30. I need to test my long handled flex head to see what I do with it- probably 35. The most I can put on anything with my stubby is 15, and that's nearing the pain threshold for my palm. For situations where it's hard to get a torque wrench in place, knowing this stuff is essential. For example, when I do my rear wheel hubs in the next few weekends- I'm hoping my flex head will get those bolts down to 35 ft-lbs without me having to reach for something else. If I end up with 37-40, it's not like it's going to hurt those parts. I don't do this on internal engine parts- of course.
I almost forgot, for those of you who are worried about damaging bolts by over-tightening: there are charts available for maximum torque by the size of the bolt. That's not to be confused with the size of the hex on the end of the bolt- for example- a typical 3/8" bolt will have a 9/16" head. This has nothing to do with mounting parts on an engine, it's just what the bolt is rated for. Those little ones like that can probably only handle a max of 15 ft-lbs. I can spin off typical and max torque settings for SAE grade 5 bolts, but not metric. I'm sure there's a chart out there for 8.8, 10.8, and 12.8.
