Is it 5 or 5.5 quarts after BS delete...?
1.2K views 16 replies 13 participants last post by  Lil PZEV
#1 ·
Okay, getting ready to do the infamous bs delete today via Cosworth's new kit. I know the OE oil level is 4.5 quarts, according to MM site its 5 quarts after the bs deletion, then I remember reading somewhere, (either here or on FJ), its supposed to be 5.5 quarts after the deletion. Can any one shed some light on this...? Thanks...
#2 ·
its 5.xxxx i dont remember exactly cause i just run a full 6 qts. its not gonna hurt anything and i'm to lazy to measure.
#4 ·
I have put a full 6 qts. in mine to since deleting the BS.
#5 · (Edited)
Assuming that the removed parts are completely under oil in their location inside of the engine, place the parts in a container and add a light oil (or water if you're not likely to reuse the parts) until they are covered and mark the level on the container. Remove the parts allowing as much of the oil to drip back into the container as is feasible. Mark the new level. Using a measuring container add oil back up to the first mark and add that difference volume to your original 4 1/2 qt oil refill.
Another thought. Why not just refill to the normal "full" mark on the dipstick?
#10 ·
in 2.3 duratecs there is a balance shaft assembly that we like to remove.
#13 ·
PDQEagle said:
This is a rediculous thread. Just go by the dipstick, that's what it's for.
These are the kind of things you keep to yourself................. If your just gonna type BS than don't even bother. [thumb]
