I was in the process of removing the center console on my 2005 focus wagon. The book that I have (chilton) tells me to remove the knob from the automatic shifter. I did as the book instructed, which was to remove the small screw on the side of the shifter knob and then pull the knob off the top.
When I did, two things came off with the shifter knob, a rod that I assume is the button actuator for the actual shifting, and a pair of wires with a 2 pin connector at the bottom. Then the book says "installation is the reverse of removal". That's very cute, but I can't even see how both of these items had enough room to even travel down this shifter tube together, much less have any room to RECONNECT the overdrive wire. I can see the connector, down at the botton of the shifter tube. How do I put this back together?????
Please help!
Thanks!
Please help!
Thanks!
