Hmmm... THAT'S not good!
4.6K views 29 replies 8 participants last post by  Boosted olds
#1 · (Edited)
I was driving home the other day, and as I went up a hill the car started stumbling and losing power... it was in gear and moving, so the engine was still making noise; but pressing the accelerator wasn't eliciting a change in engine noise. It stopped happening and worked as usual; and then I got a few miles further and closer to home when the gauges blinked, the needles fell and the digital readout changed to dashes all the way across!
I used an Actron code-reader to try and pull codes and figure out what happened, but there is no communication with the PCM through the OBDII port!
I still wanna get the car in the air and feel around for the cables between the battery, starter, and alternator... iirc; the PCM was thought to be fried last time something like this happened and it turned out the cables had gotten fried when the alternator ess'd the bed. I'm hoping it's as simple as that; but assuming the cables aren't crunchy and destroyed: what could have happened?!?
#4 ·
There was a guy who came on here not even a week ago with the same problem, and we told em about that wire, and Tom ended up coming on and saying that wire is a ground wire for the ECU fault, and that it would affect the things you are talking about.
I'll see if I can find the thread.
EDIT: ah here it is, see if this helps.
http://www.focusfanatics.com/forum/showthread.php?t=289343
IDK if they found a solution for him.
#13 ·
I was working and traveling up ta PA to pick up my Matco 5s tool box... I didn't get a chance to crawl under it. Graduating school (HELL YEAH Boosted Olds; we effn' made it!) and starting a regular day schedule should afford me the time I need this week.
#19 ·
well its to the right of the battery, I know because I had to try and make a new one for this girl. She didn't take care of her care (but thinks she does) and it broke right there at the terminal. It wasn't enough to kill it, but the speedometer would act like a tach. It's called the redundant ground and ford likes to use it a LOT for their computer system. A lot of people buy replacement battery cables and don't understand why that one is there so they leave it off and wonder why their truck doesn't start (then they don't believe me when I tell them that's what it is [facepalm])
check it out though, it's pretty easy to find.
#21 ·
Checked these:
They are all tight and secure; the wires all seem intact. I did continuity testing on them and there must be at least one strand through each of them 'cause there's continuity...
Then I got under the biotch and looked and poked the cables between the alternator and starter... everything is secured and the cables don't feel crackly or burnt...
#22 ·
Hey Keefs; was it the drop testing that tells you how intact the cables are?! I think I'm gonna have to reconnect the battery, drop test the cables (remove some of those plastic looms for some of 'em), and then drop test each side of the fuses... UGH!
I'm also gonna see if a coworker can print me a copy of the pinpoint tests for the "Dashes of Death" symptoms... EFF!
#25 ·
So, I looked at everything here:
And it is all still secure, no corrosion, and the wires look and feel intact internally.
And I also looked here:
The cable between the alternator and starter is in fine shape, unlike last time this happened and it was blackened and crispy.
The issue I'm having with inspecting the electrical is all the plastic looms covering large portions of the cables. I'm having a bear of a time figuring out where the positive cable goes after leaving the battery...
