I see the "generic electronic module" in ZX5 diagram. Is it same as "ELECTRONIC CONTROL MODULE (MAIN COMPUTER)"?. Is it the box located under hood near window?
Thanks!
Thanks!
No. Electronic control module is the ECM or as most commonly called the PCM (powertrain control module). GEM is more for body electronics like windows, locks, timing issues, etc.
If you look at diagram, you will konw the Blue and Blue/Red wires to GEM for ZX. Is there any GEM in focus? If I type GEM for focus in ebay, it will give me ECM.
Thanks!
What is the problem you're having?
Odds are it's not a problem with the GEM, which sits in front of the PCM (on that little swing out plastic arm).
2002.5 there was a switch IIRC.
Older than that will look similar to this:
Newer will look similar to this:
Related Threads
Focus Fanatics Forum
posts
5.8M
members
203K
Since
2003
