Just curious if anyone has put together a spreadsheet with all the Forscan asbuilt data "hacks" to change or turn on features yet? F150Forum has a quite extensive spreadsheet for this but I'm guessing theirs may differ from our MK3 Focus.
I've been looking for a "Forscan spreadsheet for the Focus" as well, but haven't been able to find one. It seems that most Focus owners that are inclined to try such changes use FoCCCus instead, which uses pulldown menus for changing things instead of having to tweak codes directly.
Has anybody managed to track down such a spreadsheet?
Personally, I've found the FoCCCus program to be "scary" as while it starts up (and later when it programs anything) the displays in the car indicate all sorts of temporary errors and many DTC codes remain after each use. However, Forscan seems to be able to perform operations without resulting error messages appearing on the displays in the car and lots of DTC codes after use.
I started working on one a year ago, but I could only do so much since I only had a modified ELM327. Unfortunately for that project, my situation changed and I no longer have the car.
I was able to disable the double honk, enable the "courtesy wiper" function, and I think one other feature, and I made YouTube videos for those if you're interested.
