Engine warning light came on.
I bought a code reader and got code P2008 "intake manifold runner control circuit."
This explained the slight sluggishness at low rpm.
I swapped the inlet manifold for another because I assumed there might be something wrong and, either way, I wanted to see how it worked.
That didn't make the fault go away but I learnt a lot about the configuration. I did some testing tonight to see if a vacuum was present at the two solenoid valves located on the top of the engine. By swapping the wires over I figured out that the rear solenoid valve has failed. I swapped the pipework and wires over so now the front valve is controlling what the rear valve used to do. The pipe that used to connect to the front solenoid is now connected directly the vacuum so it's always on.
I've just found a thread that explains exactly the same problem and the same conclusions via a google search. Can't link it because I haven't posted enough on here.
ÂŁ26 for a new part on Ebay: ford 1357313
What I'm intrigued to know is what the two vacuum operated items are . One operates at the inlet manifold runners and I assume this the "swirl valve". The other seems to connect to the middle of the manifold. Is it some sort of tuned runner length flap?
