Hi guys,
I'm having an intermittent problem which is becoming more consistent.
The car:
'03 16V 2.0L (Engine VIN code 3)
The problem:
Engine cranks fine, starts and runs for about 1 second then immediately stalls. Most commonly happens on cold starts. If you hold the gas pedal down for a few seconds when starting and for a few seconds after it runs, it will then stay running when you lift off the pedal. No obvious driveability issues.
There are NO fault codes stored.
I have already replaced the IAC valve since it seemed so likely given the symptoms. I also used my scan tool to change the IAC valve positioning and it did not seem to track well with the commands.
I'm going to try MAF cleaning next and check the TPS.
Any more ideas or heard of this problem before?
Thanks
Also, the car seems to vibrate more at idle in gear more recently.
The car:
The problem:
Thanks
