Ok so many of you may already know i had purchased a set of stage 2 cams from mcnews which basically were sapposed to work like the FR stg2. They are actually mcnews' custom grind, and when comparing to the stock cams did have a lot more duration and quite a bit more lift. I also bought a set of adjustable cam gears and did the install.
The car was idling really rough in part because my 02 sensor wasnt plugged in, regardless it is now plugged in and i had DaSilva Racing do a dyno tune using my Xcal2. The results...
118whp and 131 tq [?|]
Not impressive for stg 2 cams, full 2 1/4 cat back , BBP 4-2-1 race header, Magnaflow HFC, AEM CAI, and UDP
The issue, the guys at da silva have never done adjustable cam gears on a focus before therefore would not touch them. They are set at 0-0 right now.
I went to the track and could only muster a 16.3, but had a decent 2.4 60ft (granted it was 30 degrees celcius)
Where do i go from here? i could try adjusting the cam gears myself but that i am sure is dangerous.
Also when i start the car the idle is pretty high, like 1200rpm...
Is the tune no good (btw thats with 91 octane) , is it because the cam gears need to be adjusted.? i need the experts on this one.[bawling]
by the way i will put up the dyno sheet when i get home
