1 - 7 of 7 Posts
rooby_roo
· Registered
Discussion starter · #1 ·
hi all, i have a problem with the mrs focus, and where better to get some advice than on here, well basicaly every now and then when she comes to a junction it cuts out, stalls, also the mileometer cuts out so you cant see how fast your going, are these 2 connected, any ides what could be causing the cutting out, i took it to my local garage and they cleaned out the idle valve (i think thats what it was) but no difference, thanks in advance. [cheers]
If y loose speedo , first chk for battery connections, ground under airfilter, and that battery voltage is ok if so answer is most likely VSS , if ECU looses signal suddenly when rolling, the engine will behave the way yours do.
1 - 7 of 7 Posts
