Hi,
I have a 2002 and have noticed a weird 'thing' with the brake lights.
When the car is idling in park the brake lights work fine. The moment I depress the lock button on the shifter to change out of park(foot on the brake to release lock of course), the brake lights illuminate and never go out. I can pump the brakes but there is no change. Permanent brake lights illuminated.
Also, the high mount brake light never goes on. Whether the car is in park or not. I have checked the bulbs and all of them(4 or 5) are fine. I have checked the manual and brake lights are all on the same fuse so that is not the problem.
Signals work fine along with emergency blinkers.
This occurs if the head lights are on or off.
Am I missing something here? Is there another fuse or bulb that I should check?
I did have a tail light burn out and the signal indicator changed sounds as a reminder to replace so perhaps this is not a problem but a reminder to change something. I just do not know what.
Any thoughts would be appreciated.
Cheers.
Cheers.
