can someone please humor me and tell me why the hell a 99 si (b16a) when turbocharged numbers are way better than a SVTs especially under high boost??? (see for yourself on clubcivic, or clubsi.com)
x 10crazymechanic said:probably because the SI has VTEC and a much better flowing head
inschool VTAK would not matter, all depends on engine setup. p.s. what kind of numbes are we talking,
i hate to say but its true.....oh wow did i just say that? [paranoid] *runs and hides* [paranoid]munkyv22 said:Because the b16 motor is a bullet proof motor and VTEC is from the gods and the ZETEC engine is... well... Come on!?! It's a Honda motor versus a Ford, who did you think would win?
3redzxs said:Why does it matter? There is always something faster. I love my focus because it's fun to drive. I'm sure a new ZO6 would be more fun but I vowed never to own another GM vehicle after the last screwing I took. And then there is the price tag.
Honda can build whatever they want but I doubt I'll be buying. I've never owned a honda car but I've dealt with honda's motorcycle division. Not as bad as GM, but no thanks.
incorrect sir. our VCT only changes the timing of a fixed lift/duration cam. a VTEC system uses two different sets of lobes with different lifts and duration. one set of lobes has a lift/dur for low rpm tq, and the other set of lobes has a different life/dur for high rpm hp. when the VTEC activation rpm is reached, a solenoid allows oil pressure to engage a second set of rocker arms that ride the second set of lobes. VTEC basically gives you two camshaft profiles on one cam. our VCT only changes the timing, not the lift/duration. I do believe that honda does have an i-VTEC which incorporates a similar VCT system in addition to the VTEC03OrangeSVT said:The JDM hordes around here aren't any compitition.
FYI we also have VCT..... which is a FULL time version of Vtec. But basically they are a more efficient engine.
It's not loyalty to my Focus. I'm not sure what the point is, guess I'm not competitive enough when it comes to what I happen to own.dwdgsi03 said:Nice to see your loyaly to your Focus, but you missed the point completely.
