AC light wont come on
30K views 10 replies 8 participants last post by  FocusKnot
#1 ·
so pretty much my problem is pretty self explanitory. When i tried to turn on the \AC the light did not turn on and obviously the ac doesnt turn on/ blow cold air. assistance would be much appreciated. looked at the AC sticky but i am still not quite sure where to start.
#2 ·
1) Does the air blower work? If not, then that's your first problem.
2) Have you checked the AC fuse?
3) Carefully pull the AC relay out and swap it with the low or high beam relay, turn on the lights, check appropriately. If the lights don't work, then you need a new relay. These relays will be difficult to remove, wiggle, pull, and hold the relay box down with the other hand.
4) Check to see if the AC comes on with the temp set to cold, and the vent selector on DEF. (maybe this should be step 2) Look at the front of the pulley on the AC compressor, if it is turning then the compressor is on, if it is not turning then it's off.
OK let me know if any of those work. If the AC works on step 4, then your switch itself is bad. If you still haven't gotten it working, then we'll move on, but right now I have to give up the computer, sorry.
#5 ·
We'd appreciate an update or a resolution. I personally don't care about rep, but I do care about whether or not you were able to locate the problem, and if the advice helped, or if you found another way to check things. Feedback helps us with future diagnoses.
