Brother, I have had the EXACT same issue. Let me tell you my experience with this: it's possibly not a stuck canister purge valve; you may have blockage in your fuel tank vents.
As noted, there is a recall on the EVAP purge valve, and you should get that recall work performed; it might fix your issue. Replacing this canister purge valve, which can become stuck in the open position, is SUPER EASY. Ford stealerships are generally happy enough to do this for you.
However, as noted, this ultimately wasn't my issue. I had the recall work done TWICE at two different dealerships. Replaced canister purge valve. Still threw the same P1450 code: "Unable to bleed up fuel tank vacuum".
I put off the repairs and just lived with the check-engine light, thinking that it wasn't really a big deal. In my case, everything else ran fine, so why bother?
THEN I ran out of gas on the interstate during rush hour. This was extremely dangerous and stupid. My fuel gauge was still showing 1/8th of a tank!
What had happened was that the plastic fuel tank had deformed enough to cause the fuel gauge to be off. The cause of this was actually not the specified recall work, but blockage in the vent lines running from the fuel tank to the charcoal EVAP can and, ultimately, external atmospheric air.
My fix was to get under the car, disconnect the lines running from the fuel tank to the evap system, and blow them out with about 25 psi of compressed air. Problem solved, no more CEL, no more p1450.
Further info on p1450:
This code is thrown because there is an excessive amount of vacuum in the fuel tank. This can only be cause by two things:
1. Your canister purge valve is stuck open, and the engine is constantly drawing a vacuum against the fuel tank. Ordinarily, the purge valve will close once the engine has evacuated all the gas fumes stored in the charcoal EVAP canister that all modern cars have as part of the emissions control systems.
2. Your fuel tank is somehow sealed shut, and outside atmospheric air pressure cannot get into the tank to displace what your engine is sucking out of it (either through normal fuel depletion -or- through the periodic EVAP canister purge cycles that your emissions control equipment performs to make the EPA happy).
If your fuel tank has deformed to the point where the engine is starving itself for fuel because it cannot overcome the vacuum pressure that has built up inside the fuel tank — and you therefore can't get the motor to idle properly without revving it up — this is potentially dangerous, and your fuel gauges could be off.
If I were you, I would not let the fuel tank get below about 1/4 tank from now on. I know mine is truly empty before hitting 'E', but that's only because I was unlucky enough to have run out of fuel in rush hour traffic!
