Made mention of this issue in the car project thread, but I'm starting a thread on this specific issue to see if it brings up any previous threads to look at.
I don't see a viable path for removing the broken portion of the bolt without removing the subframe. Looking for anything about removing the subframe, I seem pretty much have to look at steering rack replacement procedures and videos.
I guess my specific questions are - for a vehicle I intend to flip - is there anything I should consider replacing while I'm in there? Are there things I probably want to avoid having to unbolt? (I know the RH control arm has been replaced on my vehicle, the LH has not)
As far as I can tell, the path of least resistance is to replace the subframe from salvage. I'm priced around $75 for a bare k-frame, which is honestly all that I need. But I might consider what I would want to leave bolted up. I do know that at least one vehicle in salvage has a brand new RH strut, so I'm probably going to look at that vehicle knowing it's had suspension service and might have new control arms.
I'm already under the assumption that I'm taking this vehicle for alignment when it's done due to replacing the rear subframe, avoiding that cost is a ship that already sailed... with that said, I probably want to ensure I end up with a front suspension that CAN be aligned without bolts breaking. But I don't want to get sent down a rabbit hole of replacing front suspension if I can help it.
What might I need to know about interchangeability? Is the subframe going to be Zetec specific, or do I have a wide range of interchangeability like I did on the rear subframe?
