Ok guys, I have a 1999 Mercury Tracer (same as Ford Escort) with an 2.0 spi swapped from a Focus from what I can tell from pictures online. I have low engine idle problems where the oil light comes on at a stop, engine vibrates and shakes real bad at stop, and speratic idle speed. I figure my problem is the pcv valve after looking at my setup but that's where the problem comes into play.
From what I can tell I don't have a PCV valve inline at all. The valve cover on the escort spi and focus spi are different and plumbed different so whoever did the swap didn't plumb this right. I need to plumb this right and either hook up my pcv valve correctly or add one, I'm not sure which. Ive attached pictures.
In one picture I have arrows labled 1-4 that I will use to discuss this.
Arrow 1 is plumbed straight to a small air filter. I believe it needs to be plumed to the air intake filer at Arrow 2.
Arrow 3 is plumbed from the Valve cover to the Air intake manifold. I think that I need to go from the manifold down to around arrow 4 where I believe the PCV valve is supposed to be but isn't from what I can tell.
That leaves me wondering where Arrow 3 is supposed to be plumbed to. Also where does the end of the PCV line hook up to down by Arrow 4.
Please help me sort this out I am very confused by all of this. I will try to get better pictures if needed.
