I just had Recall 18s32 performed, somehow I didn't see the mailer and the dealership didn't bring it up when I visited before. I discovered the recall when I had codes P0456 and P2196. I took it in and had the dealership perform the recall. They updated the PCM module software but did not replace the CPV, evaporative emissions vapor canister, or fuel tank. I thought from reading the recall that they needed to replace the CPV but the dealer insisted that they didn't. This is the text of the recall that I found: https://static.nhtsa.gov/odi/rcl/2018/RCMN-18V735-0635.pdf Now I've driven about 150 miles since the recall was performed and I have a new code "P1450 - Unable to Bleed Up Fuel Tank Vacuum" This sounds like it is caused by the CPV not functioning?
Is there a procedure to check the valve? The dealership near me wouldn't perform the recall without me paying a $220 diagnostic fee so I had to go to a dealership further away. I'm not expecting them to replace the valve but I can do it myself if that is the problem. I downloaded the shop manual but I cannot find the section that goes over P1450.
