08 Focus Tuning is ready
17K views 181 replies 22 participants last post by  NemesisEnforcer
#1 ·
The 08 Focus software xcal3 is ready to go 399.00 and 20.00 for shipping and you also get free updates , most places charge 35.00 for each update
#30 ·
*sergeant voice from full metal jacket* NOOOOOO! You little maggot! You do NOT regret buying an 09! Drop down and give me 50!
[:D]
the 09s are awesome, we will get out tune too soon enough [drinking]
#8 ·
do all the tunes for the various years have the same affect, let's say a tune gives you 5hp will it give that no matter what year focus you have or does it vary by year (assuming the engine is a 2.0 duratec)
What should someone expect with a tune on an 08?
#11 ·
hey tetra, did you have to modify the o2 sensor when you added your header? or did you just say screw it to the CEL?
#15 ·
I did use the mechanical fix. You don't modify the sensor itself, all you do is add non-foulers to space the sensor away from the heat so it does not throw the CEL.
I wouldn't be able to stand driving with the CEL, because what if it's actually another problem?
#21 ·
sorry about the threadjack but a 2.5 header should bolt up the same to a 2.25 exhaust right? I know i could find this somewhere but figured this would get a quick reply.
#24 ·
When I talked to Trubendz they recommended going 2.5" if you had any mods such as intake, header and so on.. They recommended 2.25" only if you don't plan on modding it.
But yes, it should bolt up fine. hatchesrock has a 2.25" exhaust with the F2 header.
#25 ·
ok awesome, yeah i kind of regret not going 2.5 now but i think it should be alright... and I just found out that I dont need emissions check until 2012!!!
yay header. yay tune!
#26 ·
I recommend you do the mechanical fix anyways. If you disable the sensor with a tune, once you go in if they plug into the OBD-II port and see a sensor is turned off you'll fail. But if you disable your tune you'll get a CEL which will make you fail. So just do the mod man, it costs like 5 bucks and it's very easy.
#32 ·
No , If the sensor is turned of they have no way of seeing it is turned off , it just means when the ECU configures it just bypasses that test like it wasent even added to the ECU , no way of knowing its off it will just act like its working perfect
#40 ·
You beat me Brad. How about YRZ1???
