2 weeks ago my hatch would not open. i can hear the relay clicking behind the glovebox but not dice. to make matters worse my key never worked [but no big deal since the dash button & fob did the job].
so, i check the forums, fuses and such, climb in the back and using a screwdriver push on the release latch.
next, i remove the latch assy-no issues that i find, cant' figure it out.
call steve at tousley ford-order a new latch assembly, new lock assembly [pre-set to my key via my vin]. it arrives today, i install it and...nothing. electric release still no worky.
i peel back the rubber accordian looking boot that is between the hatch and body and...find one wire with exposed copper, 3 that are cracked and 1 completely broken. splice, tape and repair now it all works.
wanted to give anyone here with the same problem a fix. i would also suggest electrical taping the wires so they no longer chafe within the rubber sheath.
figured i saved a couple hundred doing it myself between the dealer labor hours and price increase on the parts i purchased with our nice discount from steve.
