Current conditions:
P0304 - Cylinder #4 misfire
Bank 1 too lean (not sure of the code exactly, the guy at the shop just read it to me)
Running very rough (the cylinder isn't even firing at all). It's happened once before, but was fixed. Last time it was a problem with a leaking valve cover letting oil into the spark plug seat and filling the cylinder with oil from the top down. Cleaned out the oil, replaced all spark plugs, and put a new valve cover gasket on it, and she was running fine.
The weather has also become extremely snowy lately. I am running a CAI, but I've run it in more snow than this and it's been fine.
The misfire is always preset and is not affected by RPM's. It's most noticable at low RPM's (idle in particular), as the whole motor shakes from it being so out of balance.
Any ideas, throw 'em out there. I'd also like to know specifically which cylinder is #4 (are they numbered left to right or in firing order?), as that will help me locate the issue more.
