Here's what I've got:
600W 2-channel amp
10" DVC sub wired for 2 ohm
Factory Sub (ohmmeter says 3.2 ohm)
Was wondering how you guys reccomend wiring this up?
Putting them in parallel and showing the amp ~1.2 ohm seems bad since it's just a Sony that isn't 1 ohm bridged stable. Supposedly.
Can you put different resistor loads on the two channels of the amp? i.e. wire the 10" to channel 1 and the factory to channel 2.
The amp is receiving identical mono signals on the R & L channels.
Thanks!!!
600W 2-channel amp
Thanks!!!
