What is the best way to remove relays? Wow, those things are tight.
With a tight grip and lots of wiggling for over 5 minutes I managed to get one out. The others hardly budge. And I'm reluctant to put a pair of pliers on them.
The fuse/relay box is clean and has no moisture. The contacts on the relay that I was able to remove are clean and shiny. So it isn't corrosion that is making this difficult; just tight connections. After I put that one relay back in and tried to remove it again, same thing.
Hoping there is a trick for doing this.
