I can't believe you can still get info as bad as that. haha. The screw has nothing to do with it. your idle air control will set your idle at stock no matter where the screw is. if its' idling irratically, it's only one thing. an air leak. If you used the gasket that came from fc it's usually very thin in between the big part and the idle air bypass part. if you squeeze too tight it often times pooches out. If you get air leaking from between the two your idle will go higher because you're letting more air into the tb under the big flapper than it's supposed to get. the idea is, the big flapper shuts, and the little area is the only place the engine can get air from, the valve in there controlls how much, and keeps it at idle rpm's. if some of the air is going down into the little area and bleeding under to the big area you get uncontrolled air going in and you get too high an idle. there have been thousands of problems with the fc tb and 99% of them are air leaks.
Solution: Go buy some tb gasket material from an autoparts store and lay it on the bottom of your new tb and tap around the edges with a hammer lightly, that'll give you an exact template to cut it out and it won't be so thin in that area, actually you can leave extra there intentionally and it won't interfere with anything. If you still can't get it to seal, get some gasket goo, either gasket eliminator or even silicone and put it on both sides of your gasket very thin, tighten it down and let it sit until it's completely dry, like overnight.
The screw is there for two reasons, to make sure and have a stop so the flapper does not come to rest inside the tb, which after time can cause it to stick, so it should be just barely engaged a micron before the flapper engages the tb housing. The other reason is for if you disable your idle air valve, like with the 70m tb's. when you have no more little area, you set the setscrew where you want it to idle and thats what it does, always, no fluctuations. this will trip the cel, so be warned, its not for everyone.
Hopefully one day this info will be made up in a how to and made a sticky, not because it comes up once a week, but becaus some people hear from someone else and perpetuate bad information that those who read it then pass on to others.
g
